A few days ago i got a pc, here are the specs:
KINGSTON 16 2X8GB)/DIMM/DDR4/5000Mhz
ASUS NVidia GeForce RTX 4060 Ti 8GB DUAL-RTX4060TI-O8G
ASUS PRIME Z790-P D4
INTEL Core i7-14700KF up to 5.60GHz
I updated the bios as instructed yet the xmp profile makes everything worse, what should i do.
In the bios i didnt touch anything because im not sure what should i tweak to get the pc to function at its best.
Hello @Aktavia
We understand you are experiencing issues with your recently bought PC, we will be more than happy to assist you.
Please answer the following:
· Where are you getting the 300 FPS from?
· Are you having issues while playing a game or running another app?
· Was it working properly before?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the report from the Intel® Processor Diagnostic Tool.
Jose B.
Hello Aktavia
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by attaching the required reports.
Jose B.
Hello Aktavia
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
