Hello what would be best fastest ram for not overclocked intel ultra 9 285k with gigabyte AI top motherboard.
I am a bit confused as recently very fast DDR5 cudimm ram are marketed as to be used with newest intel , but specification suggests that max is 6400 MHz am I missing something?
You should look at gigabyte's qualified/tested hardware for their board.
[Fear and the desire for control are primary motivators for shadow dwellers. ]
Your motherboard will have an XMP option in the BIOS. XMP is Intel® Extreme Memory Profile. By default this option is set to DISABLED, setting it to ENABLED will allow faster memory speeds than standard. This will for example allow CUDIMM DD5 to run at 8000+ ram speeds.
Thanks for the reply !
I understand that XMP is overclocking of memory and it increase risk of its demage and shorten lifespan - i can live with it but doas it additionally lead to shorter lifespan of cpu and other components?
I have run Intel motherboards for year with XMP enabled without any issues.
