I would like to know the running frequency of a integrated Memory Controller (iMC) for Intel CPU, by knowing this value I can roughly calculate out the bandwidth provided by a iMC so that I will know if the iMC can provide enough bandwidth for fully populated memory over all of the memory channels.
There must be an official document describe it, please help!
thank you!
Hello Zhoucengchao, I will be more than glad to provide you any technical information for public use regarding our products. However each processor's platform has different specifications, so it will be necessary to have the model number of the processor you're looking information about.
Hi Sylvia,
It can be anyone of the E5-2600 family. I just want to know where to find such information. could you please guide to do so?
In addition, I would like to know how does iMC connect with CPU? Would it be more than one memory controller inside the CPU?
thank you!
All the information available to the public can be found on the datasheets of each processor family.
https://www-ssl.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-1-datasheet.html https://www-ssl.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-1-datasheet.html
http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-2-datasheet.html http://www.intel.com/content/www/us/en/processors/xeon/xeon-e5-1600-2600-vol-2-datasheet.html
If the datasheets does not contain the information you need, you would have to contact a Field Application Engineer.
Arrow
888 427 2250
Alliance System, inc.
800 977 1010
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227302.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227302.htm
I hope this information will be helpful for you.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
