Processors
15880 Discussions
i5 12600KF support quad channel?
Luiz123
Hello team,
As the title says, the i5 12600KF support quad channel?
I could see this in the documentation.
It just mentioned dual channel only
Please note: the motherboard is B760 Gaming Plus WIFI
pressed_for_time
Valued Contributor I
As stated in the documentation the B760/12600KF combination is dual channel only. So 4 x DIMM slots = 2 X dual channels.
Luiz123
let me try to understand sir,
It means the motherboard + processor will perform a 2x Dual channel = to 1x quad channel?
first 2 slots (2x8GB) = Dual channel 1
second 2 slots (2x8GB) = Dual channel 2
Is this the logic?
pressed_for_time
This is a slightly modified graphic from the manual for your motherboard
So a single DIMM goes in slot DIMMA2 and gives single channel RAM.
Two DIMMs go in slots DIMMA2 and DIMMB2 to give dual channel.
Four DIMMs go in all the slots but works as 2 x dual channel - DIMMA1/DIMMB1 and DIMMA2/DIMMB2.
Two dual channels is just that, not a quad channel.
Using four DIMMs will affect the maximum RAM speed - refer to the manual for details.
Luiz123
ok, quad channel is not in here!
I got your point.
In that case there are spec comnbination/hardware to get Quad channel?
I'm a bit confused with that now!
pressed_for_time
Quad channel is supported by some workstation hardware and if quad channel memory is vital to you that would be an area to research.
Luiz123
I see, vital maybe not I just want to build a desktop for gaming with family, maybe quad channel "can" be ignore for this I presume, right?
pressed_for_time
Yes, quad channel hardware is substantially more expensive than dual channel and if you want to build a desktop for gaming dual channel will be absolutely fine.
Luiz123
