I just bought an i5 13600KF
The motherboard bought to go with it is an Asus Rog strix B760-F gaming.
The memory is 4 sticks of 16 Gb of Corsair memory
CORSAIR VENGEANCE RGB DDR5 RAM 32Go (4x16Go) 6000MHz CL36 Intel XMP Compatible iCUE computer memory - black (CMH32GX5M2E6000C36)
There are NO other boards in the configuration
The monitor is directly attached to the motherboard by an HDMI cable.
The computer will not BOOT and nothing is seen on the monitor. All I get are flashing status LEDs on the motherboard. Their sequence is
LED
red 3 sec
yellow(left) 22 sec
none lit 6 sec
white only 8 sec
white + yellow(right) stays lit indefinitely
Looking up the meaning of these LEDs, the first one means that the processor is not detected.
I've CHANGED motherboards and am getting the same thing.
ASUS has been ABSOLUTELY NO help
Could someone help
Should this work with an "F" type processor?
Could the processor be damaged since it's the only thing in common to both configurations?
Hi Suzdal,
It must be perplexing to experience this situation particularly if you have tried a lot of things to make it work. We will do our best to find the cause of your concern.
After reading your post, here are our findings:
1. The i5-13600KF does not have a built-in graphics chip which means that you need to add a graphics card on the unit to be able to get a display. You would not get any display when you connect the monitor to the HDMI port from the board.
To confirm, since there are no other boards inside the system, does it mean that you have not integrated a video card on the system? If yes, you need to add a discrete graphics card so the system will work.
Alfred S
Hi Suzdal,
Alfred S
Hi Suzdal,
Thank you for marking our recommendation as solved.
It is a great joy to know that our suggestions resolved your concern.
If you would like to give us an update or if you have further questions, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
