Has anyone come across the following:
i5-4430 running in Asus H87M-E motherboard (BIOS V.: 2001) with Windows 2012-R2 Evaluation.
VT-x and VT-d are both switched on in the UEFI BIOS. But when I run CPU checks on Win2012 it (VMX/VT-x/VT-d) shows up as unsupported/Not Present etc..
In the UEFI BIOS it shows that VT-x is supported by the CPU
I have tried several BIOS settings and several CPU check tools. All come up negative.
Attached the Intel Processor Identification Utility result.
I have also tried CPU-Z and HWinfo64, all the latest versions.
Is this the MoBo/Chipset or something more sinister?
Maybe Is should try a Linux boot and see what that says.
- Tags:
- Intel® VTVT-X
HI Vos68,
I am sorry for your trouble but let me help you.
Based on the processor specifications it does support VTx and VTd technologies but this could be a limitation set on the motherboard when using different Operating System.
You can check the processor specifications to confirm the compatibility at:
http://ark.intel.com/products/75036/Intel-Core-i5-4430-Processor-6M-Cache-up-to-3_20-GHz http://ark.intel.com/products/75036/Intel-Core-i5-4430-Processor-6M-Cache-up-to-3_20-GHz
My best recommendation is for you to contact the Computer Manufacture and confirm with them if there may exist a compatibility problem between the motherboard and the Operating System.
We would also appreciate users with this same configuration to share their comments.
Kevin M
Hi Kevin,
Thanks for your response.
As you said, it might be something with the Mobo manufacturer.
Since no one else reacted to the message I guess I am unique....
I will try Asus.
Marc.
