Hello, I have an i5 4460, and I wonder if his temperature is normal with Cooler box.
Doing nothing, the processor is between 37-45º, at full load 77.
I'm using the cooler box, even change thermal grease for a Akasa 455, but did not solve the problem.
I wonder if that temperature is acceptable, or run the risk of having problems in the processor.
Sorry for my English.
- Tags:
- Data Center Cooling
Hello Fummon,
This is a normal temperature. If the processor is in Idle state it should be around 37c and at full load it can go even up to 85C but the temperatures you are reporting are still normal.
Kevin m
Thank you for answering friend, so my processor reaching 77º peaks not have to worry about?
If it is getting that temperature when running at full load then it expected.
Kevin M
Hello Fummon,
Kevin m
Kevin M
