Processors
13538 Discussions
i5 9th generation no display
DWuss
Hello.. I build pc with processor i5 9th generation.. No display when i turn on. Then plugin graphic card, and have display. Why i cannot use mainnboard port vga? Processor 9th generation dont have chipset? Thanks
AlHill
What is the model number of your processor, and what operating system are you running?
Doc
DWuss
My processor model intel core i5-9400F and running windows 7 64 bit..
AlHill
Two problems:
1, your processor does not have processor graphics. Thus, the motherboard graphic ports will not work:
https://ark.intel.com/content/www/us/en/ark/products/190883/intel-core-i5-9400f-processor-9m-cache-up-to-4-10-ghz.html
2, only Windows 10 is supported on 7th Gen and later processors. Simple fact - you are not supported.
Doc
DWuss
Thanks sir.. Then i need buy new gpu 😅
AlHill
I would not do that. As I said, you are not supported with W7. If you get a processor with graphics, you will not be able to install the graphic driver.
Since you already have a graphic card, and it works, just sit back and be happy, with the knowledge that you are still unsupported (but up and running).
Doc
