Hello everbody,
im currently using the following system:
- i7-6700k + Noctua NH-U14s with 2 fans
- Corsair Carbide 300r with cable management and Noctua fans
- Asus Z170 Pro Gaming
- 16gb Corsair DDR4-2400mhz
- MSI GTX 960
- 500W be Qu!et PSU
- Windows 10 pro
I only changed the following settings in my BIOS:
- Q-Fan setup to adjust my fan speed / profile
- XMP profile 2400mhz
Now from what i've read, using 2400mhz memory anready overclocks the CPU, even though i did not change anything else and the CPU runs at 4ghz.
When i'm using the "auto" setting for the CPU clock and vcore and my CPU runs at 4ghz default, I somethimes get up to 70°C and a little more. I know this temperature is not incredibly high but since my room gets hot in the summer a lower temp is always desired. Also i've read that the CPU can be held below 60°C in the 53° range. In addition HWMonitor shows me, that the VID goes up to more than 1.4X volt, which seems very high.
Now my question:
I'd like to set the vcore from auto to manual to achieve lower temperatures (Also I adjusted the LLC level to 4 (1-7).). I've already set it to 1.26V and while running the Intel Extreme Tuning Utility I then get a CPU temp in the 55-60°C range with a max VID of ~1.36V, which is very good. What i'd like to know are 2 things:
- If the system runs stable, using a low vcore doesnt harm anything, right?
- I'm perfectly fine with keeping the cvore at 1.26. Still i'd like to know: how do I find out the "perfect" vcore? Do I just go lower in 0.01 steps and run the stress test again?
Thanks in advance
Kind regards
Hello, markdierk:
The VCC specification for the 6th generation Intel® processor is 0.55V minimum and 1.52V maximum; as long as you stay under these parameters it should not harm your system. See here for http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/desktop-6th-gen-core-family-datasheet-vol-1.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/desktop-6th-gen-core-family-datasheet-vol-1.pdf see table 7-2.
There is no perfect cvore temperature since this is something that will depend on the demand of your system tasks.
Amy.
Hello, markdierk:
Amy.
Hello Amy,
thank you for your response and help.
Kind regards,
Markdierk
Sure, you're welcome.
If you need further assistance let us know.
Amy.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
