I just set up a new system with an i7-920 on a DX58S0 mobo. I'm using stock cooling and no overclocking. If it matters, power supply is 520w. After installing the Intel Desktop Control Centre, I see that it's reporting the CPU temperature at 1^T (i.e. 1 thermal unit). Docs indicate this is really bad. CPU voltage is being reported at ~.92 when idle. The Desktop Control Centre also reports this as below normal. Also, the red CPU LED on the mobo is lit. Docs indicate this is a temperature issue affecting performance. The other temperature sensors all report normal numbers (Ambient=37, VR=42, IOH=48). I'm a bit of a newb when it comes to temperature/voltage since I'm not concerned with overclocking. I thought just plugging things in would mean everything would work well within normal operating parameters.
First off, should I reapply the heat sink with new interface material? Is this a case of thresholds being set incorrectly? What other things might cause this temperature problem? I would really appreciate some pointers.
Update: I bought some ArctiClean and Arctic Silver 5 and re-installed the stock heatsink/fan. 10 minutes of idle after boot, temperature is now reading ~54^T and voltage is at ~1.2. So it looks like the problem is solved. Will try stressing the processor now to see how it behaves.
![](/skins/images/4428ED42C6C2DA1FDD89670A160F6AFB/responsive_peak/images/icon_anonymous_message.png)
