I’ve been playing the latest Cyberpunk 2.0 Update DLC
While playing the game and monitoring my temperatures i started seeing the cpu reaching temps of 96 even some spikes to 100 degrees celsius.
The computer at idle sits at 43 degrees celsius and on other programs / games the temps sit just fine at 80 degrees max
This one case in particular scares me as i instantly closed the game after seeing those temps
Hello @Manel
We understand that you are worried about the temperature spikes you are having, however, keep in mind that is not necessarily a cause for concern.
When the system is idle, the temperature of the processor is not as high as when the system is running a workload. Having temperature spikes or having high or maximum temperatures while running a workload—such as games—isn't necessarily cause for concern. Intel processors constantly monitor their temperature and can rapidly adjust their frequency and power consumption to prevent overheating and damage.
Nonetheless, we recommend you follow this article: Overheating Symptoms and Troubleshooting for Intel® Boxed Processors
Once every step has been taken, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Hello Manel
We hope you are doing fine.
Were you able to follow the guide?
Let us know if you still need assistance by attaching the report.
Jose B.
Hello Manel
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
