Hi Natanzel,
As posted correctly by Cpt.Dogfruit, you can find a detailed comparison sheet for the two processors below.
SU3500 is obviously more powerful than Intel Atom with it's 3MB L2 Cache and 800MHz FSB over N280's 512KB L2 Cache and 667MHz system bus. Moreover SU3500 supports 64-Bit, VT and TET but of course when it comes to less power consumption, longer battery time (In case of Netbook) and saving money, N280 takes the lead and I always recommend them to mobile users who crave for longer battery times but not very much concerned about performance.
Warm Regards,
Javed Lodhi
Intel Go Green, Save The Environment!
<!--17/08/2009 16:54:25 : 62.0-->- Mark as New
Hi both, please see below, this should answer your questions:
/javascript:{} Remove Product/javascript:{} Remove ProductNamehttp://ark.intel.com/Product.aspx?id=37133 Intel® Core™2 Solo Processor ULV SU3500 (3M Cache, 1.40 GHz, 800 MHz FSB)http://ark.intel.com/Product.aspx?id=41411 Intel® Atom™ Processor N280 (512K Cache, 1.66 GHz, 667 MHz FSB)StatusLaunchedLaunchedLaunch DateQ2'09Q1'09Processor NumberSU3500N280# of Cores11Clock Speed1.4 GHz1.66 GHzCache3 MB L2 Cache512 KB L2 CacheBus TypeFSBFSBSystem Bus800 MHz667 MHzFSB ParityInstruction Set64-bit32-bitEmbeddedSupplemental SKULithography45 nm45 nmMax TDP5.5 W2.5 WVID Voltage Range1.050V-1.150V0.9V-1.1625VPackage SpecificationsThermal Specification10090°CPackage Size22mm22mm x 22mmDie Size107 mm226 mm2# of Transistors410 million47 millionSockets SupportedBGA956PBGA437Halogen Free Options AvailableAdvanced TechnologiesIntel® Virtualization TechnologyExecute Disable BitEnhanced Intel® Speedstep TechnologyIntel® 64Intel® Demand Based SwitchingIntel® Turbo Boost TechnologyIntel® Hyper-Threading Technology<img alt="Yes" src="ht...- Mark as New
Thank you Cpt.Dogfruit!
I had posted the difference highlighting the main feature and performance differences but mistakenly between SU3500 and N270 but thank you for posting the comparison sheet for N280 and the correction, much appreciated!
Thank you, have a nice day!
Warm Regards,
Javed Lodhi
