My intel core i7 13700K processore temparature between 30-40 degree celcius on idle time. But, when my cpu is more 80% temparature increasing to 100 degree celsius. How can I fix it?
Processore : intel core i7 13700K
Motherboard : Gigabyte Z790
Cooler : Thermalright Aqua Elite 240 WHITE V3 ARGB CPU Cooler
How can I fix it?
What's wrong? Possibilities:
1. The block is improperly attached to the processor.
2. The TIM (heatsink paste) has failed, is insufficient or is improperly applied.
3. The cooling unit is improperly attached to the motherboard's fan headers (two should be connected for many liquid cooling units).
4. The motherboard's fan speed control subsystem is improperly configured or insufficient in its response to rising temperatures.
5. The motherboard has a problem.
6. (Unlikely) The processor has a problem.
Hope this helps,
Hope this helps,
Yes Thanks. Is the cooler is preferable for this?
I don't think (and didn't say) that the cooler (itself) is insufficient or not preferable. I think that there is something wrong with the setup.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
