when i starting ipdt test suddenly i press 'stop test' and press 'start test' so test result is fail.
but if i dont press 'stop test'and keep testing result is always pass
what the problem? my cpu is wrong?
this is my fail test result
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2016-03-01 오후 9:07:35
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Tue Mar 01 21:07:35 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz
End Time: Tue Mar 01 21:07:35 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 66 degrees below max
End Time: Tue Mar 01 21:07:36 2016
Total Time: seconds: 1
CPU Brand String Test
Start Time: Tue Mar 01 21:07:36 2016
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz
Module - GFX.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i7-4960X CPU @ 3.60GHz
Processor Information: Intel64 Family 6 Model 62 Stepping 4
Number of Physical Cores: 6
Number of Logical Cores: 12
Installed System Memory: 8 GB
Operating System: Microsoft Windows 10 Home 64비트
Graphics Information: NVIDIA GeForce GTX 980 Ti
System Product: X79 EXTREME4
System BIOS: P3.70
System Serial Number: To Be Filled By O.E.M.
--- IPDT64 - End Time: 2016-03-01 오후 9:07:50
--- IPDT64 - Result: Fail
System Information
System BIOS: P3.70
System Information
System BIOS: P3.70
--- IPDT64 - End Time: 2016-03-01 오후 9:07:51
Module - CPUFreq.exe did not create a results file.
System Information
System BIOS: P3.70
According to the protocol you've posted, the tool didn't create two of the expected result files. That appears to be a bug in v3.0.0.23 of IPDT; I suggest you update to the latest version (v3.0.0.25) and retry.
Were you able to run the latest IPDT version?
Allan.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
