Processors
16260 Discussions
lane margin tool runs abnormally
wxy1993
Linux environment LMT Revision 0.77, running scan, there is no RC and upstream port information, only downstream port information; running lmt, it prompts port not ready, try again...
>>> start = runLMT(Accept_License, Files_Name, Run_Scan, Segment_Count, Run_LMT, Execute_Lane_Reversal, input_dic)
Linux OS
Seg 00, Bus 0xFF, Dev 31, Fnc 0
PCI scan complete: 321 Functions
Devices found at PCIe 4.0/5.0 and L0:
|--+ DSP + +-----+-----+ USP + + +----------|
|S |B |D |F|C | PCI-Express | Neg | Neg |B |D |F| DSP | USP | |
|e |u |e |n|a |Device/Port Type| Lnk | Lnk |u |e |n| DIDVID | DIDVID | Retimers |
|g |s |v |c|p | | Spd | Wid |s |v |c| | | |
|00|a1|00|0|00| Downstream Port| 5| 16|a2|00|0|0x80011f53|0x10011af4| 0|
|00|a1|01|0|00| Downstream Port| 5| 16|a3|00|0|0x80011f53|0x10011af4|
RamyerM_Intel
Hello wxy1993,
Thank you for posting in the communities. I want to better understand the issue that you are experiencing. May I please know the specific product that you are reporting? This will help us identify troubleshooting steps suited specifically to your device. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello wxy1993,
I am just following up regarding the specific product that you are reporting. Please share this with us so we can better assist you. I will be waiting for your reply.
Ramyer M.
wxy1993
hi Ramyer M,
Thank you for your reply. I have solved this problem. The server only supports gen3 at most, which causes port not ready.
RamyerM_Intel
Hello wxy1993,
Thank you for responding back to us and for sharing the limitation you encountered. Seeing that you no longer need support for this issue, I will proceed in closing this case instead. Should you need assistance in the future, feel free to create a new thread as this one will no longer be monitored.
We wish you the best in your future endeavors!
Ramyer M.
