Processors
14583 Discussions
need help with upgrade
witch one is better? qx9770 or i7 920?
my specs are
evga 790i ultra sli mobo
4gb ddr3 2000mhz gskill kit
qx9770
i dont know if i need to make a upgrade yet (move too i7, or dont)
What are you using the system for? Are there applications that are compute intensive that you wait around for them to complete? If so, are these applications memory bandwidth limited? The i7 has QPI and integrated memory controllers, memory bandwidth is significantly increased. If this is a gaming system then my guess is that an upgrade is not warranted (frames per second would be your criteria there, and that is more than likely limited by the graphics card).
Here's a side-by-side comparison of the two processors
http://ark.intel.com/Compare.aspx?ids=37111,34444, http://ark.intel.com/Compare.aspx?ids=37111,34444,
The X5570 i7 has a max memory bandwidth of 32 GB/sec. The comparison above doesn't tell you what the memory bandwidth for the QX9770 is, but you can find that in various reviews and seems to be in the 5-6 GB/sec range. As you can see, there is a 5x to 6x improvement in memory bandwidth, which would be the major reason for you to upgrade *if* your applications are memory bandwidth limited.
Here's a review of the QX9770 that includes memory bandwidth
http://hothardware.com/Articles/Intel-Core-2-Extreme-QX9770-Performance-Preview/?page=4
Message was edited by: amdn
