cmartin87, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
Was the PC working fine before without showing the overheating problem?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
In the following link you will find "Overheating Symptoms and Troubleshooting for Intel® Boxed Processors":
The T-junction of the Intel® Core™ i5-12600K processor is 100°C, any temperature result below or equal to that value is considered normal and expected for this unit:
In order to rule out a possible hardware problem with the processor, please install and run the Intel® Processor Diagnostic Tool, it does an overall test on the unit and if it passes the test it means it is working properly:
Albert R.
Hello cmartin87, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Please disregard this post. I based my cpu temp observation on a single piece of data which I found out was due to a bad steel series patch which displayed wildly false CPU temps.
cmartin87, Thank you very much for your response.
Perfect, no problem at all. We completely understand and we will close this case as per your request.
Any other inquiries, do not hesitate to contact us again.
Albert R.
