17326 Discussions
processor intel 2 duo cpu t6600
gaschmidt
which intel processor do i need to replace processor intel 2 duo cpu t6600 for using windows11
VARADHARAJAN
Valued Contributor II
@gaschmidt
Windows 11 supports 8th generation processors; you need to change processor with supported motherboard. ram module, ssd.
Windows processor requirements Windows 11 supported Intel processors | Microsoft Learn
AlHill
@gaschmidt   Do not listen to @VARADHARAJAN    There is no processor that is supported by W11 that will replace your T6600.
Your processor uses a 478 socket:
https://www.intel.com/content/www/us/en/products/sku/37255/intel-core2-duo-processor-t6600-2m-cache-2-20-ghz-800-mhz-fsb/specifications.html?wapkw=intel%20core%202%20duo%20t6600
Even if there were a processor available, you would have to consult with the laptop manufacturer and ask them which processors are compatible with their bios.
However, do not let any of this stop you from trying to upgrade to W11:
https://community.intel.com/t5/Processors/Processors-TPM-and-Windows-11-24H2/m-p/1647361#M79106
[W10 is today's XP ]
