Processors
16022 Discussions
processor is unable to reach max cpu frequency
siddhant_shatapathy
I am currently using Asus tuf dash f15(2022) laptop and i found something recently. The cpu I have is i5-12450h which supports Intel turbo boost technology upto 4.4GHz. But the maximum frequency my cpu can reach is 3.3 GHz. So I am guessing cpu is not using the p cores n intel turbo boost is not working.I tried checking it in bios but its not showing in bios. My bios is also updated n windows is updated too. May be its a problem with w11 22h2 but I have no idea.
Its a new laptop and i don't know what to do. Any kind of help is appreciated.
Thank you
Siddhant
n_scott_pearson
I suggest that you discuss this with Asus. It may be they they have set very low limits so that they can get away with using a cheaper cooling solution...
Edit: Limits are set in the BIOS. Rare for laptop manufacturers to allow these limits to be modified.
hughor
creo que es solo un error en la lectura ya que me contacte con intel y el procesador alcanzo 4.1GHz pero aun así mostraba que estaba a 3.3 GHz como máximo
