I completed my build, had everything plugged in correctly etc. Computer boots for 1-2 seconds, won't even get to POST, and the computer shuts off. There is no beep from the motherboard, and the system continues to try and boot until I cut the power.
CPU: Intel Core i5-2400 LGA1155Motherboard: ASRock Z68 Extreme3 Gen3 The debugger code on the motherboard displays the error: "invalid CPU type or speed." Given that this is a new, modern motherboard with a socket that is most certainly compatible with the CPU, is this a motherboard issue or a CPU issue? What is the best fix? I have installed the CPU twice and triple and quadruple checked all cables and connections, and this error is the only thing that's shown up so far (then again, booting doesn't get far past that).Link Copied
I would suggest testing the processor on a 2nd motherboard, perhaps a friend's motherboard or by taking the processor to a local computer store to be tested, this way you can be sure that the processor is the defective component.
If that is the case, I would then suggest calling your local Intel support center for any warranty option.
You can find the contact information for your local support center at:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
![](/skins/images/7401F9E63DBEF6591994FAF4318EC80B/responsive_peak/images/icon_anonymous_message.png)
