I have a computer that has been freezing randomly. The user said he had bsod with a kernel error, while I was testing it I just saw it freezing, even when it is not under heavy use.
I run OCCT CPU and CPU Linpack tests and they both failed after 30seconds. I run the Intel Processor Diagnostic Tool and it failed as well. All the coolers seem to be working correctly. Could you please help me find what the problem is? Below are the complete results from the Intel test.
Thank you very much.
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 05/10/2016 12:55:51 p.m.
Processor 1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Wed Oct 05 12:55:51 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Wed Oct 05 12:55:51 2016
Total Time: seconds: 0
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 36 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Expected CPU Frequency: 3.50
Detected CPU Frequency: 3.50033
Expected Base Clock: 100
Detected Base Clock: 100.009
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Wed Oct 05 12:55:52 2016
Total Time: seconds: 1
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Wed Oct 05 12:55:52 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 475.2
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Oct 05 12:55:54 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Wed Oct 05 12:55:54 2016
Test Result - PASS
Operation Per Second: 6.64579e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Oct 05 12:55:56 2016
Cache Test
Start Time: Wed Oct 05 12:55:56 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
IMC Test
Module Version: 1.0.7.64b.W
Start Time: Wed Oct 05 12:55:57 2016
Test Result - PASS
XXXWHITESP...
- Tags:
- Solutions
There was an issue reported a while back about overheating with this type of processor model. The problem was fixed with BIOS update or even changing some settings at bios level.
Please take a look at the following post:
If the problem remains, you can call our support center and check warranty options for your processor.
http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Allan.
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
