Processors
16308 Discussions
ram compatibility for LGA771 & LGA775 cpu's?
MFry1
Hi all,
Can anyone point me in the right direction to find information on ram compatibility for LGA771 & LGA775 cpu's?
Thanks in advance for any help you can provide.
m_fry
Allan_J_Intel1
Thanks for joining the Intel community.
Memory compatibility for processor with LGA775 and LGA771 depends on the motherboard maker. Those processor sockets do not integrate MCH or memory controller hub, this means, the board maker provides memory compatibility information.
See the following link for processor comparison: http://ark.intel.com/compare/35428,36893 ARK | Compare Intel® Products
Allan.
MFry1
Hello Allan,
Thanks for your reply.
The following is a direct quote from Corsair 'The newer memory is currently higher density which will not be compatible with your CPU.'
There clearly seems to be some confusion regarding this issue even with the makers of ram.
m_fry
Allan_J_Intel1
Thanks for the information.
For memory compatibility with motherboards with LGA 771 and LGA775, I recommend contacting the board maker.
Allan.
