Processors
14642 Discussions
rare chip. SL96CA - 3000DP/4M/667. will it work in my motherboard?
please check this link:
http://support.asus.com/CPUSupport/detail2.aspx?SLanguage=en&cpu=Dual-Core%20Xeon%20L3110(3.00GHz,1333FSB,L2:6MB,E0)&m=P5BV-C&pcb=1.01G&sincebios=0403&memo= http://support.asus.com/CPUSupport/detail2.aspx?SLanguage=en&cpu=Dual-Core%20Xeon%20L3110(3.00GHz,1333FSB,L2:6MB,E0)&m=P5BV-C&pcb=1.01G&sincebios=0403&memo=
motherboard is a Asus P5BV-C. i do not know if it has the latest bios with Wolfdale/Yorkfield E-0/R-0 stepping. it should support C0 and C2 stepping. is that good enough to flash the bios to get the E-0 and R-0 stepping, plus any fixes.
since my processor is 667mhz, that is the speed of the memory i bought.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131242 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131242
the url of my motherboard can be found her @ newegg.
The SL number provided seems to be incorrect. Please double check this information or let us know the model number of the Intel® Processor in order to confirm compatibility and other details.
For accurate information about compatibility you can contact the motherboard manufacturer.
