Processors
16439 Discussions
using itp-xdp 3br for icelake
rjstjrl
Hello
I want to connect using the xdp tool kit, but I don't think it's set up well.
The server's cpu is not identified using the xdp port.
The server cpu is Intel(R) Xeon(R) Gold 6330 CPU @ 2.00 GHz.
The drivers installed are as follows.
The driver installation manual was provided by the company that purchased the server, but the following message appears.
C:\Windows\system32>dflaunch -m ipccli.start
"WARNING: IPC_PATH environment variable is set and this OpenIPC instance will be"
" used. If this is intentional you can ignore this warning, otherwise"
" please unset the IPC_PATH environment variable and rerun the script."
" Note that this variable might be defined globally/system-wide."
Python 3.6.10 |Intel(R), Inc.| (default, Apr 29 2021, 14:50:37) [MSC v.1916 64 bit (AMD64)]
Type 'copyright', 'credits' or 'license' for more information
IPython 7.13.0 -- An enhanced Interactive Python. Type '?' for help.
Connecting to IPC API....
IPC-CLI: 3.21.4834.100, OpenIPC:Main (rev 694520) : 21.48.5905.200
Initializing IPC API....
Info - OpenIPC configuration 'ICX_LBG_XDPA'; probe plug-in(s): 'XDPA'
Info - Added debug port 0 for probe XDPA 1-5
Warning - No TAP devices detected on JTAG chain 0
Warning - One or more device may be powered off.
Warning - No TAP devices detected on JTAG chain 1
I wonder what the problem is. I'd like you to let me know the related manual. Thank you.
BrusC_Intel
Hello, rjstjrl.
Thank you for posting on the Intel Community Support forum.
I received your ticket regarding this particular tool, and I will be reviewing this with you.
There is no specific support area for that product, our recommendation is to contact DesignInTools@intel.com or reach out to the point of sale or tool provider, as there is no information/assistance we can provide from the processor's support side.
The thread will be closed right now, and it will no longer be monitored by Intel support, but if you require any type of assistance from Intel in the future, just open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
