21615 Discussions
10 errors on my analog input signal (smart led) code pls help!
library IEEE;
use IEEE.STD_LOGIC_1164.all;
ENTITY sirisha IS
port ( temp :in std_logic_vector(6 downto 0);
CLK :in std_logic;
enable :in std_logic;
day , night :out std_logic;
disp :out std_logic_vector(2 downto 0)
end sirisha;
ARCHITECTURE structure of sirisha IS
signal temp :std_logic_vector(6 downto 0);
signal CLK :std_logic;
signal enable :std_logic;
signal day,night :std_logic;
signal disp :std_logic_vector(2 downto 0);
constant TCLKH_C :time:=5ns;
constant TCLKL_C :time:=TCLKH_C;
constant TCLKL_C :time:=(TCLKH_C + TCLKL_C);
constant TRDELAY_C :time:=TCLKL_C;
constant TRHOLD_C :time:=1ns;
component sirisha
CLK :in std_logic;
end component;
cur_st_process (CLK,enable)
begin
if (enable='0') then
cur_st <= start;
else if (CLK'event and CLK='1') then
cur_st<=next_st;
end if;
end process cur_st_pr;
nxt_st_process (cur_st,temp) --next state comb. circuit
begin
if(temp>"1000110")then
nxt_st<= day;
else if (temp<"0110010") then
nxt_st<=night;
else
nxt_st<=cur_st;
end if;
end process nxt_st_pr;
reg_pr : process (enable,CLK)
begin
day <='0';
night <='0';
disp <="000";
else
day <='1';
night <='1';
disp< ="001";
end if;
end process reg_pr;
begin
(temp=>temp,CLK=>CLK,enable=>enable,day=>day,night=>night,disp=>disp);
end structure;
i want the code to turn the led on(high) or low(off) based on the value of nxt_st_process (cur_st,temp).i.e at x>70 ADC value the leds should on else te leds should go off when it is at 50 adc value...i cant make it to compile successfully..pls help
You have a lot of issues I am not good in VHDL but you need a begin after your architecture and before your concurrent statements also for else if it should be elsif. In your process blocks you name the process but you need a colon and word process before your brackets. Here is some info.
http://www.gmvhdl.com/process.htm
http://www.vhdl.renerta.com/mobile/source/vhd00005.htm
http://www.ics.uci.edu/~jmoorkan/vhdlref/ifs.html
