21611 Discussions
10170 Verilog Error
module tcounter (CLK, CLR, ENP, ENT, Q);
input CLK;
input CLR;
input ENP;
input ENT;
output [3:0] Q;
wire [3:0] inc;
treg4bit register(
.CLK(CLK),
.IN(inc),
.RESET(~CLR),
.OUT(Q)
if (ENP & ENT) begin
if (Q[2] & Q[1] & Q[0]) begin
inc <= 4'b1111;
end
else if (Q[1] & Q[0]) begin
inc <= 4'b0111;
end
else if (Q[0]) begin
inc <= 4'b0011;
end
else begin
inc <= 4'b0001;
end
end
endmodule
Errors:
Line 15 (10170): near text if, expecting endmodule
Line 19 (10170): near text "&", expecting "." or another identifier
Line 22 (10170): near text ")", expecting "." or another identifier
Any help would be much appreciated http://www.alteraforum.com/forum//images/icons/icon11.png
Hi mage76,
there are several issues in your example:
As inc is a wire, you need an assign statement for logic.
Or define inc as reg, then you could use always @*.
'inc' (as reg) is not initialized, this will infer latches, i am sure you don't want this!
Or use inc as reg in combination with 'always @(posedge CLK)', this will infer FFs instead of pure combinatorial logic.
If your intention is to create combinatorial logic only you should use '=' instead of '<='.
I say this in the nicest possible way - you need to find a good book or tutorial on how to write Verilog code. this (http://www.asic-world.com/verilog/verilog_one_day.html) is a good starting point.
