21613 Discussions
2 Transceivers PLL issue
gbessa
I'm using Cyclone 10 GX Development Kit. I'm trying to use the 2 SFP ports at the same time. I already used one and everything was good: I used Triple Speed Ethernet IP (PCS+PMA version) + ATX PLL + Reset Controller.
Now, for the 2 SFPS, I added to my Platform Designer another instance of each IP with exactly the same parameters, but there's a Critical Warning about PLL Spacing:
"Critical Warning(18234): ATX PLLs are 0 ATX PLLs apart. For ATX PLL VCO frequencies between 7.2 GHz and 11.4 GHz, when two ATX PLLs operate at the same VCO frequency (within 100 MHz), they must be placed 6 ATX PLLs apart."
So my questions are:
1) How to solve/arrange PLL Spacing?
2) Can I use the same PLL for both transceivers?
3) If yes, how should I connect the signals? should I use the same Reset Controller for both transceivers?
ZiYing_Intel
ATX PLLs' VCO frequency offset must be 100 MHz apart. For further information about the PLL Spacing, you may refer to link below Section 3.1.1, https://www.intel.com/content/www/us/en/docs/programmable/683054/20-1/transmit-plls-spacing-guidelines-when.html
It need depends on the transceiver type that you use. If you are using the XCVR, you can do the PLL sharing.
You need to aware some rules when you are doing the PLL sharing. You need to ensure that you are using the same frequency, same refclk and same side of bank.
You can use the same Reset Controller for both transceivers if you want to control the resets at the same time.
Zi Ying
ZiYing_Intel
Thanks for submitting the issue.
Please do allow me have some time to look into the issue and I will get back to you with findings.
Zi Ying
ZiYing_Intel
Zi Ying
ZiYing_Intel
Since no hear any feedback from you, I am now close the issue. If you have any question after the case closed. Please do feel free to submit another issue.
Zi Ying
