2-port RAM
I am beginner of using dual port ram. My write clock is 3 times slower than my read clock? Is it possible to read the correct data from output ram?
I would appreciate if you could response me faster.
Yes. No problem. You need dual clock dual port RAM.
Hi Artem-bond,
Thanks for your quick response.
Do you have any simple example for this including the testbench?
Just use the megafunction. It will allow you to fully specify the RAM using a GUI. Very good for beginers, and the code works, so no need to build a testbench for the megafunction.
You will need a testbench for your code though.
