21611 Discussions
32-bit memory with byte access
You can generate a 32-bit memory with byte access using Megafunctions.
I like to write Verilog code that Quartus recognizes as a standard megafunction.
Quartus has a variety of Verilog examples for memory, but not one for memory
with byte access. Just for my own satisifaction I would like to find Verilog source
that Quartus would recognize as memory with byte-access.
See the coding guidelines for Q11.1
You need to use SystemVerilog for infered RAMs with byte enable access
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
Page 11-30
that looks like what I wanted to know - now to try it!
