50MHz to 1Hz
Hi,I am new planning FPGAs and I need to do a digital clock and I need a frequency of 1Hz. Someone would be able me to say as I obtain this frequency from 50MHz?
divide it by 50 000 000
Depending on what you want to do with it, it may be a better idea to do a clock enable rather than a new clock signal.
Use a counter. In your 50MHz clock domain; count to 25,000,000. Each time you reach 25,000,000 toggle your 1Hz clock and reset your counter:
module clk_1( input clk_50mhz, input reset_n, output reg clk_1hz ); reg count; always @(posedge clk_50mhz or negedge reset_n) if(!reset_n) begin count <= 25'd2499999; clk_1hz <= 1'b0; end else begin count <= count + 25'h1ffffff; if(!count) begin count <= 25'd2499999; clk_1hz <= ~clk_1hz; end end endmodule
