I am interested in 5M40ZM64I, 5M80ZM64I, 5M80ZM68I but don't seem to see them widely stocked in the mBGA package only the larger EQFP E64 package.
Has anyone used the mBGA package, does it exist?
The N Suffix indicates RoHS (SnAgSn solder balls).
Presumably without the N suffix they are SnPb solder balls?
Are they available without the N suffix?
I have managed to find DofC and Material Data for N Suffix mBGA parts like 5M80ZM64I5N, 5M80ZM68I5N, 5M40ZM64I5N with SnAgCu solder balls but not for without the N suffix, do they exist and are they SnPb solder balls?
https://www.intel.com/content/www/us/en/collections/content-type/mdds.html
5M80ZM64I5N、5M80ZM68I5N、5M40ZM64I5N is still in stock
Email:jack@aceicc.com
WsApp:+8615999908188
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
Sorry for the delay. For more information regarding your request. It can be accessed through the link below.
Link : MAX® V Device Family Overview - MAX V Device Handbook, Section I, Chapter 1 (intel.com)
Hope that helps and please do let me know if I can assist you further.
Nazrul Naim
I have seen the overview but that won't tell me if all options are available to buy.
I can see that in Industrial and Automotive temperature grade only speed 5 is valid (not speed 4).
I can see from the market that M64I5N, M68I5N (RoHS SnAgCU solder balls) are available.
But what about without the N Suffix (SnPb solder balls)?
The same with the EQFP package: E64I5N is widely available with Matte Tin (Sn) finish but what about without the N Suffix (SnPb solder)?
Do you have DofC and Material Declarations for non-N suffix parts?
MBGA: 5M40ZM64I5, 5M80ZM64I5, 5M80ZM68I5, 5M160ZM68I5, 5M240ZM68I5?
EQFP: 5M40ZE64I5, 5M80ZE64I5?
Can you recommend Distributors for non-N-Suffix parts?
Thank you
Sorry for the delay. For your information, the devices that you have mentioned above are not available in our system database and it is also not available at our authorized distributor. We only have the part number that end with 'N' suffix which means it is ROHS compliant.
I'm truly sorry for the inconvenience. Do let me know if I can assist you further.
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
