68 pin FPGA
Mike-PSEG
Is there a device I can use to replace a few Altera EP1800 devices with the same pin out?
Mike
NurAiman_M_Intel
There is no pin to pin replacement for  Altera EP1800. You may need to consider to use the latest device.
Aiman
FvM
your are asking for a 5V programmable logic device. There are very few devices still available these days, e.g. Atmel/Microchip ATF15 series. ATF1508AS in TQFP100 would fit an SMT adapter board that can be soldered or plugged to EP1800 PLCC68 footprint.
Mike-PSEG
Thanks for that information.
I know this is a tough problem. I'm trying to support older equipment that uses the Altera EP1800.
I'll look into the ATF device.
I appreciate your help!!
Mike
NurAiman_M_Intel
Aiman
Mike-PSEG
NurAiman_M_Intel
  •  I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
