21592 Discussions
7- Segments pin assignment for Cyclone IV EP4CE6E22C8
Hello:
I wrote simple program to count on 7 Segments Display in my board Cyclone IV EP4CE6E22C8.
module seg( input clk, output segA, segB, segC, segD, segE, segF, segG, segDP ); reg cnt; always @(posedge clk) cnt <= cnt+24'h1; wire cntovf = &cnt; reg BCD_new, BCD_old; always @(posedge clk) if(cntovf) BCD_new <= (BCD_new==4'h9 ? 4'h0 : BCD_new+4'h1); always @(posedge clk) if(cntovf) BCD_old <= BCD_new; reg PWM; wire PWM_input = cnt; always @(posedge clk) PWM <= PWM+PWM_input; wire BCD = (cnt | PWM) ? BCD_new : BCD_old; reg SevenSeg; always @(*) case(BCD) 4'h0: SevenSeg = 8'b11111100; 4'h1: SevenSeg = 8'b01100000; 4'h2: SevenSeg = 8'b11011010; 4'h3: SevenSeg = 8'b11110010; 4'h4: SevenSeg = 8'b01100110; 4'h5: SevenSeg = 8'b10110110; 4'h6: SevenSeg = 8'b10111110; 4'h7: SevenSeg = 8'b11100000; 4'h8: SevenSeg = 8'b11111110; 4'h9: SevenSeg = 8'b11110110; default: SevenSeg = 8'b00000000; endcase assign {segA, segB, segC, segD, segE, segF, segG, segDP} = SevenSeg; endmodule
then i connect these pin assignment
clk --> pin 24
segA --> 143
segB --> 144
segC--> 141
segd --> 142
segF -->138
segG -->2
segDP --> 3
after i run this code , only the blue small LED works not the 7Seg !!
now how can i run the 7 Seg ?
also how can i count the & seg by pressing the push bottom ?
thank you
Seems like the following part of the code will keep always the variable BCD_new at the same condition:
Which board do you use? For the boards I have used I was able to find a .csv file with the pin assignments, which I could import. That, in combination with a board-specific top layer for the mapping of the ports to the pins, makes it easier to see the connections and know the assignment has been done correctly.
I dont have the csv file , its a Chinese board. how can i get it ?
zr tech v2.00
I got it from the board vendor.
