Programmable Devices
21600 Discussions
7 Seven hardware for SOPC???????????
Hi everybody,
I'm doing a designing for SOPC, I want to use 7Segment and in SOPC system, Which component do I need to use 7 Segment.?????
Do I need PIO? Is it 7Segment?
7 bits output PIO
oh................. problem!
Dear>>>>>>>
On my Board, there are 4 seven segments led. If I choose 4 output, if I choose so we won't have any pin to choose LED(there are 4 led, which led will it choose and How to choose when it only 7bit output?)
waiting a rely?
why dont you answer my question? I'm doing and have many problem about it?
please!!!!!!!!!!!!!!!!!
For each 7seg display you need 7 output pins in your softcore processor that you connect to the physical pins on your FPGA. The pio module of SOPC builder allows for 32 outputs: So, just choose 4*7=28 outputs and you're set!
