21611 Discussions
91c111 ethernet hangs
I seem to have a problem with the ethernet driver hanging during board boot up and initialization. I've got a Stratix II interfacing to an SMSC 91c111 ethernet chip in what is similar to a VESA standard interface. My board interface is similar to that of the Stratix II DSP board, if anyone has familiarity with that.
It seems as though during board initialization, if I have an ethernet cable hooked up to the ethernet port, (ie. I am connected to a network), the board boots up fine.
When there is no ethernet cable hooked up, the ethernet driver initialization sequence gets stuck and hangs.
Has anyone seen this before?
I'm running a Nios II processor, Stratix II FPGA, and some other stuff. I've built everything in Quartus 6.0 SP1, and the SOPC builder.
It can occur either because of DHCP or because of Auto-negotiation process.
It is possible to try to remove DHCP in IP stack settings. In old versions (6.0 or early) it was necessary to correct a code of phy initialization of 91c111. During Auto-negotiation at not connected cable it came to the end on timeout and the critical error was caused.
