Programmable Devices
A PLL problem.
EEren
I created a new project for MAX10 10M50SAE144I7G and copied a PLL and ADC modules in it.
component pll is
port
	 inclk0 : in std_logic := '0';
	 c0	 : out std_logic;
	 c1	 : out std_logic;
	 c2	 : out std_logic;
	 c3	 : out std_logic
end component;
component adc_qsys is
port
	adc_1_command_valid          : in  std_logic                     := '0';             --  adc_1_command.valid
	adc_1_command_channel        : in  std_logic_vector(4 downto 0)  := (others => '0'); -- .channel
	adc_1_command_startofpacket  : in  std_logic                     := '0';             -- .startofpacket
	adc_1_command_endofpacket    : in  std_logic                     := '0';             -- .endofpacket
	adc_1_command_ready          : out std_logic;                                        -- .ready
	adc_1_response_valid         : out std_logic;                                        -- adc_1_response.valid
	adc_1_response_channel       : out std_logic_vector(4 downto 0);                     -- .channel
	adc_1_response_data          : out std_logic_vector(11 downto 0);                    -- .data
	adc_1_response_startofpacket : out std_logic;                                        -- .startofpacket
	adc_1_response_endofpacket   : out std_logic;                                        -- .endofpacket
	clk_clk                      : in  std_logic                     := '0';             --  clk.clk
	reset_reset_n                : in  std_logic                     := '0'              --  reset.reset_n
end component;
U_SYS_PLL : pll
port map
    inclk0  => OBE_CLK,
	 c0		=> s_pll_clk_120M,
	 c1      => s_pll_clk_100M,
	 c2      => s_pll_clk_30M,
	 c3      => s_pll_clk_10M
U_SYS_ADC : adc_qsys
port map
	clk_clk        => s_pll_clk_10M,
	reset_reset_n  => '1',
	adc_1_command_valid          => adc1_com_valid,
	adc_1_command_channel        => adc1_com_channel,
	adc_1_command_startofpacket  => adc1_com_startofpacket,
	adc_1_command_endofpacket    => adc1_com_endofpacket,
	adc_1_command_ready          => adc1_com_ready,
	adc_1_response_valid         => adc1_resp_valid,
	adc_1_response_channel       => adc1_resp_channel,
	adc_1_response_data          => adc1_resp_data,
	adc_1_response_startofpacket => adc1_resp_startofpacket,
	adc_1_response_endofpacket   => adc1_resp_endofpacket
And it compiles OK.
Then I added a process for all channels scan.
type AdcStateType is (ST_WAIT_FOR_TRIG, ST_SELECT_CHAN, ST_SET_CHAN,
                      ST_START_CONV, ST_WAIT_FOR_DONE, ST_DATA_READY);
signal Adc1State : AdcStateType := ST_WAIT_FOR_TRIG;
SYS_ADC_SCAN : process(glob_clock)
variable chan : integer range 0 to 9 := 0;
begin
    if rising_edge(glob_clock) then
        case Adc1State is
            when ST_WAIT_FOR_TRIG =>
                adc1_ena <= '1';
                chan := 0;
                adc1_com_valid <= '0';
                if (adc1_start = '1') then
                    Adc1State <= ST_SELECT_CHAN;
                end if;
            when ST_SELECT_CHAN =>
                adc1_ena <= '0';
                chan := chan + 1;
                if (chan >  then
                    Adc1State <= ST_WAIT_FOR_TRIG;
                else
                   case chan is
                       when 1 => adc1_com_channel <= "00000";
                       when 2 => adc1_com_channel <= "00001";
                       when 3 => adc1_com_channel <= "00010";
                       when 4 => adc1_com_channel <= "00011";
                       when 5 => adc1_com_channel <= "00100";
                       when 6 => adc1_com_channel <= "00101";
                       when 7 => adc1_com_channel <= "00110";
                       when 8 => adc1_com_channel <= "00111";
                       when others =>
                   end case;
                    Adc1State <= ST_START_CONV;
			    end if;
            when ST_START_CONV =>
                adc1_com_valid <= '1';
                Adc1State <= ST_WAIT_FOR_DONE;
            when ST_WAIT_FOR_DONE =>
                if (adc1_resp_valid = '1') then
                    Adc1State <= ST_DATA_READY;
                end if;
                --timeout
                adc1_timeout <= adc1_timeout + '1';
                if (adc1_timeout >= X"249F00") then  --20 ms
                     adc1_timeout <= (others => '0');
                  end if;
            when ST_DATA_READY =>
                case chan is
                    when 1 => adc1_1_data <= adc1_resp_data;
                    when 2 => adc1_2_data <= adc1_resp_data;
                    when 3 => adc1_3_data <= adc1_resp_data;
                    when 4 => adc1_4_data <= adc1_resp_data;
                    when 5 => adc1_5_data <= adc1_resp_data;
                    when 6 => adc1_6_data <= adc1_resp_data;
                    when 7 => adc1_7_data <= adc1_resp_data;
                    when 8 => adc1_8_data <= adc1_resp_data;
                    when others => Adc1State <= ST_WAIT_FOR_TRIG;
                end case;
            when others =>
        end case;
    end if;
end process SYS_ADC_SCAN;
And Fitter generates an error
Info (15535): Implemented PLL "pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|pll1" as MAX 10 PLL type
Info (15535): Implemented PLL "adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_altpll_gr22:sd1|pll7" as MAX 10 PLL type
Error (176394): Can't fit 2 PLLs in the device -- only 1 PLLs are available
    Info (176395): Location PLL_3 cannot be used due to package or device migration constraints
    Info (176395): Location PLL_4 cannot be used due to package or device migration constraints
So I started to comment out the process lines and found out that if I remove the line adc1_com_valid <= '1'; in here
    --adc1_com_valid <= '1';
It compiles OK. How this signal makes the fitter to generate internal ADC's PLL as a system one?
sstrell
Where is glob_clock coming from?
EEren
It's coming from PLL
U_SYS_PLL : pll port map
(inclk0 => OBE_CLK,
c3 => s_pll_clk_10M );
glob_clock <= s_pll_clk_120M;
sstrell
The PLL output driving the ADC must be c0 of PLL1 or PLL3 of the device.  The no fit may be because you are not doing this.  Switch the PLL outputs around to drive the ADC with c0 and see if that fixes the problem.
EEren
Isn't it the same signal? Any way I've chaged it
SYS_ADC_SCAN : process(s_pll_clk_120M) --c0 from PLL
begin
    if rising_edge(s_pll_clk_120M) then
and the ADC module gets 10 Mhz clock as it should
port map
    clk_clk        => s_pll_clk_10M, --c3 from PLL
The problem still remains.
sstrell
Like I said, it can't come from c3.  You have to edit the PLL parameters and have the clock you want to use for the ADC to come from the c0 output of the PLL.  So the c0 output should be 10 MHz and move the 120 MHz clock to c3.
EEren
OK. I see. So I redesigned the PLL in Q-SYS. And now it's
inclk0 => OBE_CLK,
c0 => s_pll_clk_10M,
c3 => s_pll_clk_120M
But  I get the same error.
sstrell
So the tool thinks a clock is needed somewhere else and is implementing an additional PLL for some reason.  I think you'll have to check the timing analyzer to see all the clocks in your design to try to figure it out.  Generate a clocks report to see all the domains.  This might help you narrow down what is going on.
EEren
I see. To what item in the timing analyzer report should I pay attention.  Going through the report couldn't find a clue.
I have a project with the same ADC module that compiles nad runs good. I compare two reports
                                                             ------------------  GOOD PROJECT -----------------------
Source assignments for adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll
Source assignments for adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_stdsync_sv6:stdsync2|adc_qsys_ADC1_PLL_dffpipe_l2c:dffpipe3
Port Connectivity Checks: "adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_altpll_gr22:sd1"
Port Connectivity Checks: "adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll"
                                                   ------------------  BAD PROJECT -----------------------
The two reports are the same. But the Fitter reports are different. And Fitter processed on earlier stage, before timing analyzer.
; PLL Summary ;
; Name                                                  ; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|pll1 ;
; SDC pin name                                     U_SYS_PLL|altpll_component|auto_generated|pll1 ;
; PLL mode                                            Normal ;
; Compensate clock                             clock0 ;
; Compensated input/output pins    -- ;
; Switchover type                                 -- ;
; Input frequency 0                             30.0 MHz ;
; Input frequency 1                              -- ;
; Nominal PFD frequency                   30.0 MHz ;
; Nominal VCO frequency                    600.0 MHz ;
; VCO post scale K counter                 2 ;
; VCO frequency control                      Auto ;
; VCO phase shift step                         208 ps ;
; VCO multiply                                       -- ;
; VCO divide                                           -- ;
; Freq min lock                                      15.0 MHz ;
; Freq max lock                                     32.51 MHz ;
; M VCO Tap                                         0 ;
; M Initial                                              1 ;
; M value                                               20 ;
; N value                                                1 ;
; Charge pump current                       setting 1 ;
; Loop filter resistance                       setting 24 ;
; Loop filter capacitance                    setting 0 ;
; Bandwidth                                          450 kHz to 980 kHz ;
; Bandwidth type                                 Medium ;
; Real time reconfigurable                 Off ;
; Scan chain MIF file                            -- ;
; Preserve PLL counter order           Off ;
; PLL location                                       PLL_1 ;
; Inclk0 signal                                     MBT_CLK ;
; Inclk1 signal                                      -- ;
; Inclk0 signal type                           Dedicated Pin ;
; Inclk1 signal type                           -- ;
; PLL Usage ;
; Name ; Output Clock ; Mult ; Div ; Output Frequency ; Phase Shift ; Phase Shift Step ; Duty Cycle ; Counter ; Counter Value ; High / Low ; Cascade Input ; Initial ; VCO Tap ; SDC Pin Name ;
; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[0] ; clock0 ; 10 ; 3 ; 100.0 MHz ; 0 (0 ps) ; 7.50 (208 ps) ; 50/50 ; C0 ; 6 ; 3/3 Even ; -- ; 1 ; 0 ; U_SYS_PLL|altpll_component|auto_generated|pll1|clk[0] ;
; PLL Summary ;
; Name ; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|pll1 ; adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_altpll_gr22:sd1|pll7 ;
; SDC pin name                                                 U_SYS_PLL|altpll_component|auto_generated|pll1       U_SYS_ADC|adc1_pll|sd1|pll7 ;
; PLL mode                                                         Normal        Normal ;
; Compensate clock                                         clock0        clock0 ;
; Compensated input/output pins                --        -- ;
; Switchover type                                              --        -- ;
; Input frequency 0                                          30.0 MHz        10.0 MHz ;
; Input frequency 1                                            --        -- ;
; Nominal PFD frequency                                 30.0 MHz        10.0 MHz ;
; Nominal VCO frequency                                600.0 MHz        400.0 MHz ;
; VCO post scale K counter                             2        2 ;
; VCO frequency control                                  Auto        Auto ;
; VCO phase shift step                                     208 ps        312 ps ;
; VCO multiply                                                    --        -- ;
; VCO divide                                                         --        -- ;
; Freq min lock                                                   15.0 MHz        7.5 MHz ;
; Freq max lock                                                  32.51 MHz        16.25 MHz ;
; M VCO Tap                                                        0        0 ;
; M Initial                                                             1        1 ;
; M value                                                              20        40 ;
; N value                                                              1        1 ;
; Charge pump current                                     ; setting 1        setting 1 ;
; Loop filter resistance                                     ; setting 24        setting 20 ;
; Loop filter capacitance                                  ; setting 0        setting 0 ;
; Bandwidth                                                       ; 450 kHz to 980 kHz        450 kHz to 590 kHz ;
; Bandwidth type                                             ; Medium        Medium ;
; Real time reconfigurable                              ; Off        Off ;
; Scan chain MIF file                                         ; --        -- ;
; Preserve PLL counter order                       ; Off        Off ;
; PLL location                                                   ; Unassigned        Unassigned ;
; Inclk0 signal                                                   OBE_CLK                                   ; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[3] ;
; Inclk1 signal                                                      --        -- ;
; Inclk0 signal type                                           Dedicated Pin        Global Clock ;
; Inclk1 signal type                                            --        -- ;
; PLL Usage ;
; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[0] ; clock0 ; 4 ; 1 ; 120.0 MHz ; 0 (0 ps) ; 9.00 (208 ps) ; 50/50 ; C0 ; 5 ; 3/2 Odd ; -- ; 1 ; 0 ; U_SYS_PLL|altpll_component|auto_generated|pll1|clk[0] ;
; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[2] ; clock2 ; 1 ; 1 ; 30.0 MHz ; 0 (0 ps) ; 2.25 (208 ps) ; 50/50 ; C1 ; 20 ; 10/10 Even ; -- ; 1 ; 0 ; U_SYS_PLL|altpll_component|auto_generated|pll1|clk[2] ;
; pll:U_SYS_PLL|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[3] ; clock3 ; 1 ; 3 ; 10.0 MHz ; 0 (0 ps) ; 0.75 (208 ps) ; 50/50 ; C2 ; 60 ; 30/30 Even ; -- ; 1 ; 0 ; U_SYS_PLL|altpll_component|auto_generated|pll1|clk[3] ;
; adc_qsys:U_SYS_ADC|adc_qsys_ADC1_PLL:adc1_pll|adc_qsys_ADC1_PLL_altpll_gr22:sd1|wire_pll7_clk[0] ; clock0 ; 1 ; 1 ; 10.0 MHz ; 0 (0 ps) ; 1.13 (312 ps) ; 50/50 ; C0 ; 40 ; 20/20 Even ; -- ; 1 ; 0 ; U_SYS_ADC|adc1_pll|sd1|pll7|clk[0] ;
In the latter report Fitter detecs two PLL's.
lixy
Hi EEren,
May I know if this issue has been fixed?
Based on previous information, it looks like we need to check in Quartus RTL or technology map and see where is the other PLL from?
XY
