21595 Discussions
A question about Altera
Let's say i have a signal and i want this signal to take different values every clock time.How can i define these values?.For example i want for the first clock cycle the value of the signal to be 15, on the second 35 etc.My clock cycle is 15ns.So i try to use arbitary value option but when i try to insert the second value(from 16 to 30ns ) it overwrites the first cycle value.
Thanks in advance
use a look up table.
Tricky,
I think his problem is in defining values for the Quartus Simulator.
triggerman,
I think you can select just 15 ns of the signal, then set the value for those 15ns.
Thanks for the reply.And yes my problem is to define values in the simulator.Ok i found the solution.It is a bit of time consuming but it is ok.Thanks again
