Programmable Devices
21611 Discussions
A question about generate pulse signal between different clock zone
I need to generate a 124M pulse from a 52M pulse. Restrited by the pipeline stages, I use this method:
always @ ( ... posedge clk_124 )
sig124 <= P52;
end
p124 <= P52 & (~P124);
end
I wonder if this method is safe? :D
--- Quote Start ---
sig124 <= P52;
end
end
--- Quote End ---
what is the purpose of sig124? Should be "p124" the same signal as "P124" ?Be aware that verilog is case sensitive.
--- Quote Start ---
sig124 <= P52;
end
end
--- Quote End ---
Shoudn't the second process be
P124 <= P52 & (~sig124 );
end
i.e. you are generating a pulse of 1 clk_124 period when P52 is ''1' and the last value of P52 ( Stored in sig124 FlipFlop) is 0, in effect a rising edge detector.
Otherwise it should be "safe" assuming P52 is synchronous to clk_124. If it isn't you will need to add extra pipeline flipflops to reduce the effects of metastability in clock domain crossing i.e
sig124_L1 <= P52;
sig124_L2 <= sig124_L1;
sig124_L3 <= sig124_L2;
end
p124 <= sig124_L2 & (~sig124_L3);
end
