Hi all,
well am a new VHDL programmer, and I was trying to write a code for a generic multiplier using a 4 bit ripple adder, the results are correct, but my design should include two modes, test mode and normal mode, when I was trying to compile the following code, an error occured as follows. Error (10028): Can't resolve multiple constant drivers for net "output[10]" at fast_multiplier.vhd(19) here is the code LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY fast_multiplier IS GENERIC (n: POSITIVE:=7); PORT(mode,TDI,clk_normal,clk_test:IN STD_LOGIC; multiplier: IN STD_LOGIC_VECTOR(n-1 DOWNTO 0); multiplicand: IN STD_LOGIC_VECTOR(3 DOWNTO 0); result: OUT STD_LOGIC_VECTOR(n+3 DOWNTO 0); TDO: OUT STD_LOGIC); END ENTITY; ARCHITECTURE simple OF fast_multiplier IS SIGNAL input1: STD_LOGIC_VECTOR(n-1 DOWNTO 0); SIGNAL input2: STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL output: STD_LOGIC_VECTOR(n+3 DOWNTO 0); SIGNAL clk: STD_LOGIC; BEGIN g0: ENTITY WORK.multiplier_ripple(simple) GENERIC MAP(7) PORT MAP(input1,input2,output); g1: ENTITY WORK.my_mux(simple) PORT MAP(clk_normal,clk_test,mode,clk); PROCESS(mode,clk) BEGIN IF RISING_EDGE(clk) THEN IF mode='0' THEN input1<=multiplier; input2<=multiplicand; result<=output; ELSIF Mode='1' THEN input2(3 DOWNTO 0)<= (TDI & input2(3 DOWNTO 1)) ; input1(n-1 DOWNTO 0)<= input2(0) & input1(n-1 DOWNTO 1); output(n+3 DOWNTO 0)<= input1(0) & output(n+2 DOWNTO 0); TDO<=output(n+3); END IF; END IF; END PROCESS; END ARCHITECTURE; when mode=0 this is the normal mode and when mode=1 this is the test mode any help plz as soon as possibleLink Copied
output is unconditionally driven by the multiplier, so it can't be driven in the process. I guess, you would want to drive result instead.
To avoid double drive on "output" connect "temp1" to multiplier output at G0 line and assign temp2 instead of output in the line:
output(n+3 DOWNTO 0)<= input1(0) & output(n+2 DOWNTO 0); Then create a switch: if ... output <= temp1; else output <= temp2; end if;- Mark as New
Kaz is right i think.Because simple meaning of the this common error "multiple constant driver" is that compiler is unable to assign more than one value to that specified stuff that u wanted.
Because your code is simultaneously assigning more than one values to output[10],so compiler always confuses out of two values,which one i should use.So it will generate an error of multiple constant driver To resolve this,always use intermediate variable,like "temp" for storing values and use value whenever u need it to your required output.
