21615 Discussions
ACTIVE EPCQ device selection for Arria 10 FPGA
kh12
I am looking for EPCQ devices for either:
  1. 10AX027H4F35I3SG
  2. 10AX027H4F34I3SG
I found some documentation that says EPCQ-L devices are made to be used with Arria 10, however all EPCQ-L devices show up as obsolete on digikey. Which active  devices should I use for these FPGAs?
-Karla
EBERLAZARE_I_Intel
Let me know if you have further questions.
EBERLAZARE_I_Intel
Do you have the particular part number/datasheet for the EPCQ-L device that you wanted to use?
I will get back to you on more info.
EBERLAZARE_I_Intel
May I know if the EPCQ is only for FPGA portion or HPS portion?
For list of tested for Arria 10 HPS devices:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/configuration/supported-flash-devices-for-arria-10-soc.html
kh12
Just FPGA.
-Karla
EBERLAZARE_I_Intel
EBERLAZARE_I_Intel
If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
