21615 Discussions
AD DA Data Conversion Card
Hi guys.
Recently, I have bought AD DA Data Conversion card. I want to use it to convert the analog signal from my receiver to circuit to Altera DE2 115. However, I am little bit blur and confuse about it. I have read the demonstration on the web. It said that "the ad/da data conversion card was created to provide a set of analog to digital and digital to analog interfaces including an audio codec interface". Is it possible if I want to connect the receiver circuit to AD DA conversion card in order to convert the signal to digital form for DE2 115 process. Do you have ideas regarding my problem?
Thanks in advance
If the signal amplitude is too small, you need to amplify the signal before connecting the signal to the AD Conversion card.
