Programmable Devices
21602 ディスカッション
AGFB014R24B2E2EV : Customizing and Porting HPS U-Boot & Linux
MK_086
初心者
2,236件の閲覧回数
Dear Experts,
We are able to bring up the AGFB014R24B2E2EV Eval board with Yocto build U-boot and Linux from QSPI flash by following the steps as in,
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD#Build_Yocto
We would like to know the steps/sequences on how to customize the U-Boot & Linux with driver enable/disable options, rootfs path sharing, compile and port this to Eval board.
0 件の賞賛
14 返答(返信)
EBERLAZARE_I_Intel
従業員
2,216件の閲覧回数
For device tree you may refer to:
https://www.rocketboards.org/foswiki/Documentation/HOWTOCreateADevicetreeForAgilexSoC
For building rootfs:
https://www.rocketboards.org/foswiki/Projects/AgilexSoCWithEMMCStorageOnHPS#Building_Rootfs
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
MK_086
初心者
2,188件の閲覧回数
Hi @EBERLAZARE_I_Intel ,
Thanks for sourcing the links, we are on generating these images to test or load on EVM.
EBERLAZARE_I_Intel
従業員
2,186件の閲覧回数
Thanks, if you have new questions or feedback regarding the documentation let me know.
EBERLAZARE_I_Intel
従業員
2,154件の閲覧回数
Do you have any other questions?
If there are no further update for this ticket, you may help to close it.
MK_086
初心者
2,142件の閲覧回数
The link shared above to Build Rootfs is always downloading from git and compiling. Please provide us with the steps to customize files in Rootfs, launching the custom C application after Linux booting is completed.
EBERLAZARE_I_Intel
従業員
2,108件の閲覧回数
Customization of rootfs do you mean something like, as for our example we are using Yocto, so are you aiming to customize the Yocto rootfs? OR a different/custom rootfs?
Launch C application code is pretty general, you can store in the rootfs partition:
https://itsfoss.com/run-c-program-linux/
MK_086
初心者
2,093件の閲覧回数
Looking for the process/steps to store the c executable in rootfs partition and how to make it run at the Linux boot up.
EBERLAZARE_I_Intel
従業員
2,075件の閲覧回数
Thanks for confirming the info, let me check with our internal expert on that.
EBERLAZARE_I_Intel
従業員
2,046件の閲覧回数
I am still working on it, I will get back to you soon.
EBERLAZARE_I_Intel
従業員
2,042件の閲覧回数
You can access the rootfs partition and store the .c after building the img:
> Creating the eMMC Image
Are you familiar with Linux machine? You can store the .c in the rootfs/ext3, you can do something like:
https://midnightprogrammer.net/post/create-mount-and-unmount-img-files-in-ubuntu/
Then do the following when booting to Linux:
https://vitux.com/how-to-write-and-run-a-c-program-in-linux/
EBERLAZARE_I_Intel
従業員
2,036件の閲覧回数
Additionally, you can follow these steps:
https://github.com/altera-opensource/gsrd-socfpga
On the customization, you can modify the recipe in: recipes-images/poky/gsrd-console-image.bb
  1. add your c file in recipes-images/poky/files (mkdir)
  2. In recipes-images/poky/gsrd-console-image.bb, add the followings
    1. FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
    2. SRC_URI:append = " <CFILE>"
  3. Add this under nfs_rootfs() function:
    1. cp ${WORKDIR}/<CFILE> ${IMAGE_ROOTFS}/home/root
If you need help or have any questions regarding the GSRD let me know.
MK_086
初心者
2,020件の閲覧回数
The above-listed steps of GSRD help.
Does it require compiling using the bitbake_image command or is it possible to compile rfs alone? Any supported command lists would help.
EBERLAZARE_I_Intel
従業員
1,990件の閲覧回数
My apologies for the late respond, I did not have computer access for few days.
Yes, it requires bitbake_image, as of now there are no additional commands particular builds.
Do you have any further questions?
EBERLAZARE_I_Intel
従業員
1,970件の閲覧回数
I’m hope that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
返信
