21584 Discussions
AGFB023R25A external loopback 53.125Gbps PRBS checker error after initial adaptation
jason_chen8310
Hardware board: AGFB023R25A Ethernet Card + 100G QSFP28 DAC cable external loopback.
Problem:  Use the System Debugginng Toolkits com-altera-systemconsole-app-shell to debug 53.125Gbps performance. Serial Loopback is ok ( ber=0 and inject error bits is tested ok). But  BER is wrong when set to external loopback ( The message is "Hard PRBS checker error counter has saturated and checker is stopped accordingly...,  But the lock status is True and ber is showing continuely when I turn the adaptation mode to continous Adaptation).
Question: Please help me check the Serdes of FPGA setting. Now I can't see any of serdes setting on this console toolkits.
Note: hardware is ok, cable is ok , test operation procedure is OK. The BER result is OK when I tested 2 days before.
Yi
Hi Jason,
How long is your external loopback module? Firstly I'd like to suggest you try to add a bit TX EQ see if the link would be better first, just in the lower part of the Tx channel parameters.
WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
