21615 Discussions
AIIGX configuration scheme
I am using AIIGX fpga along with serial configuration device from Micron. We are using AS configuration mode, in relation to this I have following queries, any help on this would be appreciated.
1. Is AIIGX fpga support non-Altera serial configuration devices?
2. If it is possible then how can I generate a bit stream target to non-EPCS part (in my case Micron device, data sheet attached)?
3. Is there any particular care needed on PCB level to handle above scenario?
R Shaik.
