21611 Discussions
ALT2GXB on CYCLONE IV GX
Hi every one!
I'm a newbie about the GXB transceivers.
I'm trying to realize a transmission channel very simple using a Cyclone IV GX(EP4CGX15BF14C8N.
) device on a board realized in my company.
In order to test it actually i check if the PLL of the transmitter locks the pll_inclk[0].
I connected the Clock generator to the pin E7 (pll_inclk[0]) . but not in differential mode.
(PIN E6 connected to ground)
Note that the "normal" pll locks to the frequency. (100MHz)
I made a considerable numbers of attempts, but up to now i was not able to use it.
What could be the main problem?
-The clock that is not differential?
-The tranceiver needs a different clock respect to the "FPGA fabric ?"
-or both?
Best regards.
PS: I have a very similar issue on a Stratix II GX Based Board.
Your post does not state what is the result you get, and what you'd expect. Also you do not describe your setup detailed enough.
Anyway, I had a strange GX problem with Cyclone IV GX.
I instantiated an RX-only GX unit. I did follow the reset sequence recommendation, but could not see freqlocked signal to activate.
Finally I found out that if I instantiate TXRX GX and do not use TX path at all, the freqlocked signal behaved as documented.
If I remember correctly, Altera documentation says that diff-clk is mandatory if using GX blocks. You could probably tie one pin to ground through capacitor, or tie it to a voltage which is middle of input voltage swing. But the jitter performance might suffer.
If you connect the negative pin to ground, you can not configure the input *** diff (the positive input can never have voltage smaller than negative input).
BR, -Topi
Thank you very much for the reply.
I'm sorry for the few clarity
I'll try to amend in the following
I connected the Clock generator to the pin E7 and the PIN E6 to ground and i configured the PIN E7 as 2.5V (IO Standard)
I configured the GXB transceiver just as transmitter (protocol BASIC, without 8b/10B)
The inputs for the transceiver are
- tx_datain[9..0] connected to a lpm_constant
-pll_inclk[0] connected to E7
-cal_blk_clk (connected to E7)
The clock generator has a frequency of 100 Mhz
The outputs of the TX transceiver are:
tx_dataout[]
pll_locked[0]
tx_clockout[0]
The expected result is that the pll_locked Signal goes to "High" Level
But i did not get it
As i already mentioned, unsing a normal PLL (altpll Megafunction) and using the same clock the pll_locked signal goes in "HIGH" state.
I made this test because, looking at the netlist using "Resource Property Editor"tool in QuartusII i saw that the PLL of the transceiver is a separated entity of the transceiver
and it seems that is the same of the ALTPLL megafunction
and both are connected to the output pll_locked in the same way.
Thank you for the hint. I'll try to instantiate also the RX channel.
About the diff-clk: I searched in the handbook of the Cyclone IV and in the Guidelines for the connection of the pins, but i did not find
anything of mandatory
It could be very useful if you could indicate me where i can find this sentence.
Thanks a lot again
Best Regards
Dear All,
i found that the clock has to be differential in the Knowledge BAse of Altera.
(Solution ID: rd05032011_649)
Please note that the fitter (quartus 12.1) does not give any error.
Best Regards
