21601 Discussions
ALTDDIO_OUT. How to overcome restrictions on output data port?
Hello!
In the Double Data Rate I/O Megafunctions datasheet it is said, that DDR output data port of ALTDDIO_OUT ( dataout[] ) should directly feed output pins in top-level design.
But in my design I need to feed these outputs to inputs of another block inside my design.
That , of course, causes Quartus errors.
Is there a workaround for this problem?
--- Quote Start ---
Hello!
--- Quote End ---
DDR is meant for external interfacing only. Inside fpga there is no ddr support as you can just double your clock.
And you can just build it in RTL. The altddio_out is meant to call the dedicated structure built in the I/O cell.
