21611 Discussions
ALTLVDS Failing timing on simple interface
Hi
I am failing timing implementing a simple ALTLVDS The clock speed is 200MHz the de-serialization factor is 2.
I am interfacing a CYCLONE V SOC system to a two channel, 14 bit ADC (ADS4249) ADC via LVDS I have 14 LVDS lanes in total to cover both ADC channels. Each lane does two bits.
My problem is that Timequest is failing on setup time.
I have not specified any constraints in my Timequest sdc for the LVDS.
I am using Quartus 14.1. I notice that the megawizard greys out nearly all the options as soon as I select a deserialization factor of 2. Is this because ALTLVDS does not use PLLs for de-serialisation factors of 2?
Please can anyone help me get my design through timing?
Dave
Why are you using ALTLVDS IP? In my opinion this IP is not suitable for your needs. If I were you a would use simple DDR input registers with PLL.
--- Quote Start ---
--- Quote End ---
Hi Thanks. I think you make complete sense. I will try ddrio. Cheers Dave
