Hi all.
I use Quartus 11.1 SP2 to Develop Stratix IV . The Stratix IV need receive image data via LVDS interface . I use Mega-Wizard to generate the ALT_LVDSRX Megafunction IP with Quartus 11.1. It is failed .is there anyone encounter this problem?Link Copied
I'm trying with 11.1 SP2 under Linux (32 bit). I can't get the LVDSRX to run either. It starts running Java and shows about 1/3 of a progress bar and then reports a segmentation fault on the console.
Seems to be a (rather simple) problem that Altera can't solve with many Megafunction plugins.- Mark as New
Runs ok under version 10.1 (no SP) in 32 bit mode. Doesn't work in 64 bit mode due to CNX file error
