I implemented ALTLVDS_Rx with external PLL (instead of ALTLVDS_Rx with internal PLL) to control PLL settings manually. But problem of word alignment arised, I think. In idle mode only "AA"(hex) bytes are transmitted by LVDS, but processing finite state machine detects another bytes received ("55" Hex). There is a part of my project about ALTLVDS_Rx and PLL in attachment. Is it right or need some modifications ? Data rate: 160 Mbps, Deserialization factor: 8. Settings of PLL are: PLL mode: Source Synchronous Compensate clock: clock0 Compensated input/output pins: lvds_data_rx, lvds_data_rx Switchover type: -- Input frequency 0: 20.0 MHz Nominal PFD frequency: 20.0 MHz Nominal VCO frequency: 320.0 MHz VCO phase shift step: 390 ps Freq min lock: 18.75 MHz Freq max lock: 40.64 MHz Bandwidth: 680 kHz to 980 kHzLink Copied
