21616 Discussions
AN647 config.tcl error
bansarth
I am trying to run the config file for the an647 reference design on the Arria V GX 5AGXFB3H4F35C4N. Whenever I run the config.tcl file as the documentation says to to perform the tests, I get an error.
I have not changed the code at all except to move the design over to my board. Please let me know if you have fixed this issue.
SengKok_L_Intel
Could you please open the tse_marvel_phy.tcl, and add the following at line 36? Somehow this address is not defined in the TCL code.
set PHY_STATUS_ADDRESS 0x284;
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Regards -SK
